аналог 2sc1962 2sc1663
Автор katok, Мая 23, 2024, 15:50:50 PM
katok
Приветствую. Помогите с подбором аналога транзистора 2sc1962 или 2sc1663
Документации на них нет, даже по параметрам не подобрать.
katok
Type   Transistor Silicon NPN
Case   TO202
Vbr CBO   200
Vbr CEO   200
Max. PD (W)   950m
C(ob) (F)   12p
Derate (Amb) (W/°C)   10m
hfe   70
Ic Max. (A)   500m
Icbo Max. @Vcb Max. (A)   200n
Polarity   NPN
Trans. Freq (Hz) Min.   45M
@VCE (test) (V)   2.0
Oper. Temp (°C) Max.   125
@Ic (A)   100m
Pinout Equivalence Number   3-12
Surface Mounted Yes/No   NO
Maximum Collector Power Dissipation (Pc)   0.95 W
Maximum Collector-Base Voltage |Vcb|   200 V
Maximum Collector-Emitter Voltage |Vce|   200 V
Maximum Emitter-Base Voltage |Veb|   8 V
Maximum Collector Current |Ic max|   0.5 A
Max. Operating Junction Temperature (Tj)   150 °C
Collector Capacitance (Cc)   24 pF
Transition Frequency (ft):   22 MHz
Forward Current Transfer Ratio (hFE), MIN   70
SKU   395087
Ансар
